G
Guest
Guest
Hi, I have a mod i'm planning on making for my case, and basically what im trying to do is put all of the wireless stuff in the front, as for whatever reason, they don't work properly nor very far from the back *im not even 5-10 feet away from my couch, this is for an HTPC setup) anyways, I got this idea to put a usb hub inside of my case, as it has a tinted window perfect for allowing signals through. What I was thinking about doing was getting a regular usb hub, and wiring it to a usb header pin for the motherboard internal usb pins. problem is, I believe some hubs require a power plug, especially if you plug multiple or power hungry devices in.
So, my question is, would I be able connect these devices to a regular usb hub, without requiring an extra power source:
Logitech unifying usb adapter
Bluetooth micro adapter
infrared usb receiver
(possibly, not sure yet) Microsoft xbox 360 wireless receiver, or other wireless gaming receiever
if at all possible, it would be nice to have an extra free usb slot for something else down the line, but its not important. just wondering if those usb adapters all plugged into one usb hub would require too much power draw?
any help would be much appreciated. thanks
