Printer and device manager problem
hi, i had problem with my printer on windows 7..
actualy i had uninstall it on device manager when it connected with usb without the driver download is complete because of my internet connection is very low.. now my laptop cannot trace the printer when it had connected with usb..
the question is how to connect back the printer device?
1 answer Last reply
More about printer device manager problem
  1. Since the internet speed is so slow you should download the driver and save it , either on the desktop or in the download file.
    The best thing to do is to start over because if the laptop doesn't see the printer when it is connected by usb then you have a problem with the install and the best thing to do is start over.
    Go into the control panel and in add and remove software , remove the printer software and then do a reinstall of the printer so that this time there are no interuptions.
Printers Device Manager Peripherals
