you have to pull it apart and remove the power supply. where the power cord plugs in is the power supply. its not easy. if you dont know what your doing dont do it. if the fuse is blown there is probably a short circuit. seriously wouldnt bother unless you have another power supply handy to replace the current one. getting it fixed by an authorised repairer will cost more than a new printer.
