Tom's Hardware > Forum > Windows 7 > Question about running a graphics card as a capture card
I have 2 NVIDIA 275 GTX graphics cards each with 1792MB of video memory. I want to turn one of them into a capture card. Say I am playing Crysis. I run it at max settings and get 40-45 fps when my cards are in SLI and 35 fps when they are not. I use Fraps to capture a video of the screen and the fps drops to 2-7 fps even when in SLI mode. If I designate one of them as a capture card, I would expect being able to capture at 35 fps, though I have no idea how to do this. Do I need to download a different screen capturing program? If so, where do I find a free one?
2 NVIDIA 275 GTX 1792MB
Core 2 Duo 6MB 3.16GHz
128 GB SSD
8 GB DDR2 RAM Cas Latency: 4, Timing 4-4-4-12, 800MHz
OS: WIndows 7 Release Candidate
Thanks guys.
Message edited by stathakis on 08-05-2009 at 11:31:13 PM
Sponsored Links
Your framerates drop because CPU and HDD have extra load to deal with when recording
Reply to ainarssems
try modestly OCing your cpu and if that helps buy a good cooler and go for broke
Reply to ewood
its hd mostly and cpu yah, fraps record raw video data small videos (2 mins) end up being 1-2 gigs
And tbh i dont think its possible just checked it my self couldnt find anything but then again not running any kind of dual gpu setup altho i doubt it would show me any features anyways
Reply to ill b ben
the problem is the cpu, get a quad, disk is unlikely
------------------------------ "Envy is ignorance" - Henry Thoreau : Best quote ever.
http://www.pingtest.net/result/3022953.png
Reply to xaira
There are 1265 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
