Kernel-Power EventID 41 Crittical Error
I have a..
Windows 7 Pro
AMD Athlon(tm) 64 x2 dual core processor 3800+ 2.01ghz
3.00 GB
64-bit Operating System
My computer seems to run just fine if Im not playing a video game(world of warcraft), but as soon as I do it crashes within 20min. I get black screen as if my electric has gone out. Please help me!
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 5/11/2010 12:17:10 PM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: Ako-PC
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2010-05-11T19:17:10.364000000Z" />
<EventRecordID>2040</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>Ako-PC</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">false</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
4 answers Last reply
More about kernel power eventid crittical error
  1. (to the above poster, you've started off partly fine, but could add some more information for people to get a better idea of your problem :) )
    I am experiencing the same kind of issue with my PC setup at the moment, spec's are
    Windows 7 Professional 64 Bit
    i7 920 intel CPU
    EX58-Extreme Motherboard - http://www.gigabyte.com.au/search/search.aspx?kw=+GA-EX58-EXTREME+%28rev.+1.0
    Nvidia GTX 285 1gig Video Card - http://www.inno3d.com/products/graphic_card/gtx200/gtx285.html
    G-Skill 6gig 9-9-9-24 1600 Ram - http://www.memoryc.com/computermemory/ddr3ram/6gbgskillpc312800nqseriestriplekit.html
    1TB Seagate HDD
    Antec 850Watt PSU
    I have individually tested each component of my PC, Ram tested, video card, scanned the HDD , checked windows, you name it and I've done it, my issue isn't exactly the same as the one listed above but I've done enough research across the net about people experiencing the same kind of issue with similar or close enough system setups, this problem appears to be a new-generation setup issue, as it doesn't seem to be happening in the same way to systems not using a i7 920 and above CPU
    included is a dump from my event viewer, I am getting these restarts at random intervals, which have increased lately , I have updated every driver I have to the absolute latest, I am going to pickup a battery backup Power supply board to check possible Power issues...........
    I also checked the settings meationed above about sleep mode and made sure they are turned off, then it crashed afew hours afterwards, same cause same issue......
    How I get this issue is I can be doing anything in windows, and then suddenly it will decide to shutdown, it will go through a normal shutdown from the start menu, closing off everything I have opened or am doing (without giving me a chance to save), then power down.
    Once down and cold, restarting can be a pain, it will power up then down sometimes, before even turning the monitor on to start up the standard startup information you get when turning your PC on, sometimes I will get bios is corrupt messages and it will auto recover from the HPA backup (or something like that), other times it will complain that I have overclocked settings in my bios and claim that they caused the instabilities and bootup issues,
    I have had my Ram clocked to 1600 - http://www.memoryc.com/computermemory/ddr3ram/6gbgskillpc312800nqseriestriplekit.html
    this is the only overclocking I do and this issue has happened even when the Ram hasn't been setup like that......
    I've followed some tips from - http://www.tomshardware.co.uk/forum/275856-12-gigabyte-guide / and adjusted settings in the bios as well in relation to the CPU, still no change........
    Whatever this is, I can't pinpoint the issue enough to send a component back to the manufacturer for checking yet.........
    Any help would be most welcome
    - System
    - Provider
    [ Name ] Microsoft-Windows-Kernel-Power
    [ Guid ] {331C3B3A -2005 -44C2 -AC5E -77220C37D6B4 }
    EventID 41
    Version 2
    Level 1
    Task 63
    Opcode 0
    Keywords 0x8000000000000002
    - TimeCreated
    [ SystemTime ] 2010 -06 -30T18 :58 :50 .090820300Z
    EventRecordID 43905
    Correlation
    - Execution
    [ ProcessID ] 4
    [ ThreadID ] 8
    Channel System
    Computer MarcusReid -PC
    - Security
    [ UserID ] S-1-5-18
    - EventData
    BugcheckCode 0
    BugcheckParameter1 0x0
    BugcheckParameter2 0x0
    BugcheckParameter3 0x0
    BugcheckParameter4 0x0
    SleepInProgress false
    PowerButtonTimestamp 129223977612463432
    I will keep a eye for replies
  2. marcusreid - Where you ever able to locate the cause of your problem?? and the resolution?
    I am experience very similiar issues with System Event ID: 41 Task Category 63
    Log Name: System
    Date: 05/08/2010 10:26:40 PM
    Event ID: 41
    Task Category: (63)
    Level: Critical
    Keywords: (2)
    User: SYSTEM
    Computer: Colossus
    Description:
    Event Xml:
    <System>
    <Level>1</Level>
    <Task>63</Task>
    <Opcode>0</Opcode>
    <TimeCreated SystemTime="2010-08-06T02:26:40.741609200Z" />
    <EventRecordID>3730</EventRecordID>
    <Correlation />
    <Computer>Colossus</Computer>
    </System>
    <EventData>
    </EventData>
    </Event>
    Gigabyte X58A-UD3R (Rev.2)
    CPU Type QuadCore Intel Core i7 930, 3300 MHz (22 x 150)
    OS Name Microsoft Windows 7 Ultimate
    Version 6.1.7600 Build 7600
    Video: 2X EVGA nvidia 470
    G Skill F3-12800CL8-2GBRM 3X 2 GB DDR3-1333 DDR3 SDRAM (9-9-9-24 @ 666 MHz) (8-8-8-22 @ 592 MHz) (7-7-7-19 @ 518 MHz) (6-6-6-16 @ 444 MHz)
    Power supply: Cossair 750 extreme
    What I did find in my troubleshooting is that my system would not shutdown applications entirely during shutdown and they would continue running in taskmanager so upon reboot it would never shutdown and then crash system.
    One other issue that is really curious to me is that Lavalys EVerest is not able to recognize my MoBo? I am wondering if it could be something defective in the Bios.. but like you , I did everything posted on the web with no resolution.. err.
    Anyhelp would be appreciated.
  3. Well I also have asus laptop k55vm with i7 processor, 8GB Ram, 1 TB hdd and 2GB nvdia 630m graphics card...I was also facing the same problem of event Id 41(system crash). I also updated the bios and all the drivers but the same while playing games....When I complained about it the just changed the main board of my laptop and now it is working absolutely fine.....Now I am able to play all the games without any system crash....but before going to change the main board check with all the rest of the hardware and softwares.
Windows 7
