I have a Cannon ip2700 that I have attached a continuos ink supply. Everything works fine except after printing for awhile the yellow stops sending enough ink to the paper. Everything else works fine. I have chaged the cartridge and changed the yellow ink, tring different brands. Still have the same problem. If you have any ideas it would be a big help.
thank you,
Eskew
thank you,
Eskew
