How to format read only usb flash drive
please if you have the solution send it to my email address yssendikamya@yahoo.com
3 answers Last reply
More about format read flash drive
    you can format the pen drive from command prompt
    open cmd as administrator
    and write the command as follows w/o the quotes:
    "format Your-drive" and press enter
    E.g.: format G: and press enter where G: is my drive letter for pen drive
    If above command fails then use "/Q" and "/X" with space before the drive letter.
  2. Depends on the drive. If your drive is read only then check to see if the drive has a microswitch to enable the write line to the drives electronics.
  3. This is only for Transcend pen drives,
    1. Just download the 'JetFlash General Product Series' from the following link:
    http://www.transcend-info.com/Support/Software-3/
    2. Now insert your pen drive and open the downloaded .exe file
    3. Then click the format button to format and wait for some moment.
Configuration Read Only Format USB Flash Windows 7
