Need Plug & Battery to work
Last response: in Laptops & Notebooks
I have an everex SA2050T laptop that powers up when plugged into the ac adapter and with the battery installed. If I remove either one, the laptop shuts off. While plugged in the battery light indicates it is receiving a charge. It will not run at all on battery alone. It will not run on ac adapter alone. Has anyone ever experienced this? If so could you share your experience about solving the problem, or if you have a solution, I would much appreciate your kind assisstance. Thanx!!!!
More about : plug battery work
No fix in software. And trying to fix the hardware will almost always cost close to a new laptop. You'd have to try several new parts with no guarantee of a fix. New power lead connector, new motherboard. Do you unplug the battery while it's running? Can you power on the laptop with the battery removed and then turn it on? I actually run most of my laptops that way.
Ask the community
