Tom's Hardware > Forum > CPU & Components > CPUs > Mobile CPU Speed & Intel Test Utility
Forum CPU & Components : CPUs - Mobile CPU Speed & Intel Test Utility
How good is Intel Processor Frequency Identity Utility. I purchased a notebook with a 800 mhz mobile but three different utilities list the acual speed as 796 mhz (Sandra), 795 mhz (Showmhz) and 796.1 (Cpu-z). The only program that shows that the actually speed is Intel's. Are the other programs not as accurate or is Intel's not as accurate. I kind of assume that Intel's isn't that accurate since the other three programs are different but I don't have enought expertise to genuiely make that assessment. Hopefully, someone here does. Thanks
Sponsored Links
They all are! You have an 800MHz processor, but since it's running on a 99.5MHz bus, it's running slower than 800. This is a common issue with all motherboards-none run at a try clock speed, do to the frequency of the crystal being approximate.
Video killed my Radio Card!
Reply to Crashman
- 0 +
552.1 for a 550... same problem, though its going the other way...
you do not strengthen the weak by weakening the strong
Reply to killall
There are 1198 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
