Problem with system restore - UNDO INCOMPLETE
undo does not complete and error 0x80070005 appears
2 answers Last reply
More about problem system restore undo incomplete
  1. Hello Ronald_10,
    Your are using system restore correct? Since the 'undo' is incomplete, this might mean that your backup is corrupted. Try using a different backup if you have one.
    Hope this helps,
    jhansen
  2. It might be due to your anti-virus program. turn off the protection,
    restart the pc and press f8 till recovery menu appears.
    select repair computer
    then follow steps which will lead you to numerous options for recover
    now restore your computer from here.
    I am sure it will complete the restore.
System Restore Windows 7
