Audio Devices
iineviidable
I recently purchased the Avermedia Live Gamer HD capture card and the only way for it to record game audio is if i use the "audio in" port or select it as default in my playback options.
http://puu.sh/1SZpI
I use headphones with a built in usb sound card so if i select it as default i can't hear the game audio myself. (or any other audio)
I have virtual audio cable and can't figure out a way to bypass this.
What i need to actually happen is pretty much use 2 different output devices at the same time, or listen to the output devices with virtual audio cable in some way, but i can't figure out how.
Any help would be appreciated.
http://puu.sh/1SZpI
answer
Last reply
More about audio devices
Configuration
Audio
Games
Devices
Windows 7
Related Resources
- Getting 5.1 as the default audio format in Vista 64 bit
- Asus m4a79xtd evo audio drivers
- Playing two separate audio sources to two separate devices?
- Virtual Audio Cable help
- Different audio output for certain programs
- Output audio through 2 different devices at the same time
- No audio recording device
- Separate audio from speakers and headphones?
- Split audio to two separate output devices: HDMI & Desktop Speakers
- Audio only works with headphones.
- Default audio output device(s) (win7/itunes)
- HAF 922 front audio not working?
- Avermedia Live Gamer HD Capture Card & HDMI Audio
- Audio Static through AVerMedia Live Gamer HD Capture Card
- The only way to get 5.1 audio ?
- No audio playing despite audio devices *apparently* OK
- 9800gx2 internal audio cable
- Dual Audio Device Issues (MB and Sound Card)
