<b><A HREF="http://www.swiftnets.com/cpu_temp_testing.htm" target="_new">http://www.swiftnets.com/cpu_temp_testing.htm</A></b>
>><font color=red>The problem is that different manufacturers use different types/brands of probes, locate their probes in different areas of the socket, and use different formulas to calculate the temps. This results in significant variations from one motherboard to another, even with the same CPU. It is well documented for example, that Abit motherboards are on the optimistic side (reporting colder temps than actual), while Asus Motherboards are usually pessimistic (hotter than actual). Another significant disadvantage to this method is that the temperature inside the socket is highly dependant upon the amount and direction of air flow outside of the socket area.</font color=red><<
Good or Bad have no meaning at all, depends on what your point of view is.
