Cd drive doesn\'t read all audio cds
my compaq laptop does not recognize most cd,s that i recorded on the same cd drive
4 answers Last reply
More about drive doesn read audio
  1. does it read other cd? does the cd that recorded read on other computer?
  2. Have you tried cleaning the pick up lens and/or the discs? Does this happen with pre-recorded discs (store bought ones)? On those that it does recognise, does the autoplay start first time or do you have to open and shut the drive several times before it's recognised? Also, how old is it? It may be dying and in need of replacement.
    Good luck.
  3. You can try removing the upper/lower filters using the directions found HERE .
    If that doesn't help you might also be able to go into Device Manager and remove the IDE channel or SATA channel associated with the CD/DVD drive. If you're not comfortable doing something like this, let someone know and we'll try to find a step-by-step for you.
  4. Using very CHEAP discs ?
Configuration Laptops Audio Compaq CD-Rom CD Drives Windows 7
