I got the Cyborg F.R.E.Q. 5 USB headset for my computer and I can't seem to get it working. My computer uses the Realtek HD audio manager which seems like a piece of *** to me. I plug in the mic and my computer makes the noise of a USB item connecting but nothing happens. I cannot get the headset to play audio out of it or use the microphone.
I downloaded the software: Cyborg_5.1_win7_Drivers.exe
I open it up and nothing happens. So I found the program download in my downloads and ran it again. "Do you want to replace the already existing files?" Yes. So the files are clearly on the computer.
I have done it several times yes, replaced the files, no not replaced them.
I go into the folder where the files are and click "Setup" since it doesn't pop up for some strange reason and it says:
"Windows cannot find 'C:\yadayadayada'. Make sure you typed the name correctly and then try again.
Wtf?
Wtf?
