Tom's Hardware > Forum > CPU & Components > CPUs > Power Supply
Power Supply
Forum CPU & Components : CPUs - Power Supply
I am buying a new comp soon with approximatly the following
hardware
1.33 AMD CPU
MSI K-7 Master
512MB DDR ram
40 gig Hard Drive
16X DVD Player
12x10x32 CD-RW
64MB MSI GEFORCE II Pro
Floppy drive
Soundblaster live Value
Every one seems to recomend 400W power supplies but
I find that very few computer places offer power supplies
over 300W
I can buy through my friend from a wholesaler and get a great deal. Low prices and no tax. The problem is they only carry 300W cases. Will there be an issue with 300W on this sytem. I dont want to screw around changing the power supply
myself.
Sponsored Links
If you don't plan on overclocking much, 300 watts is ok. I'm using a 250 watt A-open power supply, and running my 1.2 athlon at 1.33.
Reply to o1die
- 0 +
Buy the system through your friend then change the power supply yourself. Changing the the power supply is not difficult.
<font color=green>I miss the smell of leaded gasoline!</font color=green>
Reply to zpyrd
Since your not running like 3-4 additional HDDs, your PS is sufficient enough.
<font color=blue>Your mouse moved. WINDOWS NT must restart for changes to take affect. Restart Now?[OK]</font color=blue>
Reply to Stick_e_Mouse
how does one change a PSU?
i assume u just unplug all the components, undo a few screws, remove the old, then reverse the procedure for the new?
correct?
Quote from the Hamster: "Why is it that Morons are just smart enough to understand how to breed?"
Reply to lhgpoobaa
Ja, that's more or less how it goes--aside from the standard "unplug the power supply first" that applies to ATX. The stuff in your case might be arranged such that you have to take apart a lot more to be able to get the bloody thing out...
Kelledin
"/join #hackerz. See the Web. DoS interesting people."
Reply to Kelledin
It's easy. Just four screws on the back of the case in most instances. If you do it with a brand new case it takes just 60 seconds.
By the way, as Kelledin mentioned, always unplug an ATX PSU's power cord before removing system components. This is just in case the system is in <b>standby mode</b>". Everything might look dead but the PSU is still suppling 5-volt standby power.
Reply to phsstpok
the reason why i asked is that i may have to do it with mine shortly...
cant be certain but i think my PSU is being a bit dicky on startup. and the 5v line has dropped a bit over the past week.
hmmms. must keep a close eye on it.
Reply to lhgpoobaa
- 0 +
This <A HREF="http://www.anandtech.com/showdoc.html?i=283&p=1" target="_new">article</A> will help you change your power supply.
Shut down computer.
Unplug power cord and disconnect from power supply.
Disconnect peripheral equipment.
Open computer case.
Touch unpainted metal surface to dissapate static charge. (Chassis of power supply best surface to touch.)
If components are dusty take time to blow out dust with compressed air.
Begin to disconnect 12V molex connectors from drives. (CD ROM, Floppy, Hard Drive, etc.)
After all drives and other accessories are disconnected unplug main power to motherboard. This molex connector will have a clip retention mechanism to secure it to the motherboard. Lift clip back and rock the molex body back and forth while gently pulling away from motherboard.
After all power cables are disconnected remove the screws securing the power supply to the case chassis.
Slide out old power supply gently while guiding power cables to prevent them from catching on any components within the case.
Now you can install the new power supply by reversing the above steps.
Once the new supply is installed and power cables plugged in recheck everything including pci cards, dimms etc to make sure everything is seated properly before closing the case and reconnecting perpheral equipment.
Next plug in, boot up and have fun.
Reply to zpyrd
There are 1255 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
