G
Guest
Guest
Hi, I went out yesterday and picked up a few items for my new system..but my cpu is running too hot and i need to bring the heat down to normal tempatures heres my specs
Athlon 1.4 266FSB
Gigabyte GA-7DXR Mobo
256 DDR memory
Asus V7700 GeForce2 GTS 32mb Video
Soundblast Live 5.1 Sound card
IBM 60GXP 40GB Harddrive
Lynksys network card.
Generic 300W Powersupply
Coolermaster EPH-6151 CPU Fan
Now im getting tempatures of about 60 degrees celcius which is concerning me..my main concern is my cpu fan and my power supply, currently my power supply is running 300w with only 22 amps at 5v...and ive heard it should be more like 30amps at 5v, I need to do something to get my tempature down, i also have 2 case fans, Im either going to buy a new fan like the Global Win WBK38 or 50 or the Swiftech as recomended on toms guide..and also a Enermax Powersupply either the 351p ve or 365p ve fc , although the 365 is a bit more money and wondering if i can get away with the 351p ve, anyways i really need a solution to this problem and im wondering if I would need to get a better cpu fan as well as a power supply or maybe just a new power supply any help is appreciated..thank you
Athlon 1.4 266FSB
256 DDR memory
