Closed
Help for buying a monitor
Last response: in Computer Peripherals
February 17, 2013 8:56:36 PM
I'm looking for a monitor with the following specs:
27 inches
IPS, 8ms gtg or less
Matte finish
250nits or more
1080p
VESA mount compatible
100% sRGB (higher color gamut would be appreciated)
Budget is $300 bucks. I'm not familiar with the monitor market anymore. Any help appreciated.
Thank You
More about : buying monitor
Best solution
a b C Monitor
February 20, 2013 5:46:02 PM
27 inches
Matte finish
250nits or more
1080p
Thank You
Hi - There's a few that meet your criteria, this one seemed to
be the best:
http://www.bhphotovideo.com/c/product/756159-REG/ASUS_V...
February 27, 2013 12:17:05 AM
Best answer selected by aymanhaq.
Score
