Closed
[Help]Fujicom monitor
Last response: in Computer Peripherals
February 19, 2013 5:29:42 AM
Hello,
i have a new monitor Fujicom -fj2245-Led
it is FHD 1920x1080 and connected with DVI cabel.
i have win 7 ,now when i check the resolution it says that the recommended resolution is
1280x1024 but i can still set it to 1920x1080 so i wanted to know why is it like that?
and i also wanted to ask if theres a driver for this monitor?
Thank you.
More about : fujicom monitor
Best solution
February 19, 2013 12:02:45 PM
Windows doesn't know what the recommended resolution of your monitor is, it doesn't even know what make or model or screen size it is. The display resolutions which are available are those which your graphics adapter is capable of producing. It is up to you to set it to the correct resolution for your monitor.
Fujicom do not provide any monitor drivers, I've just checked their website.
February 19, 2013 12:35:41 PM
Best answer selected by miran123.
Score
February 19, 2013 12:36:09 PM
Thank you very much :)  .
Score
