Help Buying a budget monitor
Last response: in Computer Peripherals
February 20, 2013 2:04:12 AM
I'm looking for a cheap monitor for gaming. It's the first I have ever bought one and with all of the different options and newer and older models of the same monitors, it is overwhelming to find the best one. I'm going cheap, 250 or under. 150-200 is ideal. I don't need built in speakers if that helps.
More about : buying budget monitor
a b 4 Gaming
a b C Monitor
February 20, 2013 3:47:49 PM
Hi - Some nicely priced options:
http://www.newegg.com/Product/Product.aspx?Item=N82E168... nets to $160
http://www.newegg.com/Product/Product.aspx?Item=N82E168... nets to $180
http://www.newegg.com/Product/Product.aspx?Item=N82E168... nets to $199
m
l
February 20, 2013 7:32:39 PM
Okay I wondered how the asus monitors were. I have been watching the vs247h. It was on sale at amazon for 145 yesterday. Its a cheap monitor and seems worth it so I think I might just pull the trigger on it. Thanks for the help
m
l
a b 4 Gaming
a b C Monitor
February 21, 2013 1:56:28 PM
enjoy! hopin to upgrade my 21.6" as well.
m
l
