Just finished piecing together a new amd 1.4ghz system and noticed that it was set at 1054 mhz. How do I set it to it's actual speed or should I just leave it alone?
what is your board. probabely the FSB is set to 100 MHz. 1400/133 has a multiplier of 10.5 hence 10.5x100=1050. those 4 MHz are minor deviations tat occur on all systems.
the board must have a jumper that will up the FSB to 133 MHz. chek the manual.
girish
<font color=blue>die-hard fans don't have heat-sinks!</font color=blue>
