Resolution Problem
Last response: in Computer Peripherals
- Problem with 1366x768 resolution - Windows 8.1 - Forum
- dead rising 3 resolution problem ? - Forum
- Dual Monitor Resolution Problem - Forum
- Civilization V Resolution problem - Forum
- Problem with resolution ? - Forum
- Solved32" LED TV Resolution problem Forum
- SolvedIncorrect resolution problem!? Forum
- SolvedProblem with using my monitor's highest resolution. Forum
- SolvedLG FLATRON W2243S resolution problem Forum
- SolvedAMD Vision Control Centre Screen Resolution Problem. Forum
- SolvedSamsung S22A300B native resolution problem after reparation Forum
- Solvedscreen resolution driver problem? Forum
- SolvedEyefinity 3 + 1 resolution problem Forum
- SolvedMonitor resolution problem Forum
- SolvedScreen Resolution Problem Forum
- Solved3 Monitor Set Up Resolution Problem (Nvidia Surround) (Gaming Intent) Forum
- SolvedResolution problem on Fedora 20 Forum
- Solved1080 Resolution Problem with a new HDMI cable Forum
- Solvedps3 resolution problem Forum
- Fifa 14 Not showing all resolution pls... solve this problem Forum
- More resources
Read discussions in other Computer Peripherals categories
... Its cause im kinda buying a 200$ graphic card for my computer so wanted to know whether im making the right choice. If i'm unable to fix these problem then theres no point on buying a graphic card.
. Could increase my resolution till 1600 x 900. Well i need to replace my monitor, Atleast i know what the problem is
