DoganMods
55
1. What is your budget?
£600, but if you can find a laptop that does everything i need, cheaper the better!
2. What is the size of the notebook that you are considering?
15.6 maybe 17.
3. What screen resolution do you want?
1360 x 768 minimum, higher the better.
4. Do you need a portable or desktop replacement laptop?
Well, portable but good for running mid/high demanding applications.
5. How much battery life do you need?
1-2 hours +.
6. Do you want to play games with your laptop? If so then please list the games that you want to with the settings that you want for these games. (Low,Medium or High)?
World Of Warcraft - Medium + with 40-45 fps
Call of Duty 4/modern warfare medium
Medal of honor - low/medium
Guild Wars 1/2 - Medium
7. What other tasks do you want to do with your laptop? (Photo / Video editing,watching movies, Etc.)
I go to college so,
Photoshop cs4
Serif web plus
Serif draw
(just general use applications)
8. How much storage (Hard Drive capacity) do you need?
250gb+
9. If you are considering specific sites to buy from, please post their links.
None
10. How long do you want to keep your laptop?
2 Years minimum
11. What kind of Optical drive do you need? DVD ROM/Writer,Bluray ROM/Writer,Etc ?
DVD ROM/Writer
12. Please tell us about the brands that you prefer to buy from them and the brands that you don't like and explain the reasons.
Dell isn't really my choice since they're customer service is terrible and all the dell branded laptops I've had in the past sucked. Anything else is usually fine :)
13. What country do you live in?
England - East sussex
14. Please tell us any additional information if needed.
Just need a laptop to do my general college work on and play games at the same time, my preferred cpu is i3 i5 i7 but it doesn't really matter
thanks guys!
