and installing windows ~ Does matter if I use my windows XP or 7 disc ~ My hard drive will format then restart over and over ~ Also if I do with using my Windows 7 disk it will still show it trying to boot into windows XP ~ ?
Also I dont use the quick format ~ I go the long route ~ Once its reformatted I cant get it to install Windows XP or 7 ~ ? All it wants to do is restart over and over ~
My son was using it a college and it started hanging up on start up so I walked him through formatting and it will do that find I believe ~ Just want install windows XP or 7 afterwards ~
Any ideas ~ ?
CPU AMD llx2 500 unlocked to 4 cores
Motherboard ASUS M4A785TD-V
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131398&SortField=0&SummaryType=0&PageSize=10&SelectedRating=-1&VideoOnlyMark=False&IsFeedbackTab=true#scrollFullInfo
HD is a Western Digital WD Blue WD3200AAJB 320GB 7200
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136109
4 Gigs of G. Skill DDR3 1600 Ram ~
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231193
Antec NEO ECO 620C 620W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS Certified Active PFC Power
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371031
Any ideas ~ ?
