Solved
Audio problem in win 7
Hello,
In win7 64 (desktop) I can't enable speakers and headphones to work simultaneously: it's one or the other (very annoying). (IDT Audio drivers ok) In Vista they worked perfectly together. Any workarounds, please? Thank you!
3 answers Last reply Best Answer
More about audio problem
  1. Best answer
    did you install the generic windows drivers or the manufacturer's drivers? I know with my realtek-based chipset, i needed to install the manufacturer's drivers to be able to output from 2 channels simultaneously.
  2. Best answer selected by JuniLewis.
    You are right, the new win 7 install used default drivers. New downloaded Realtek drivers solved the problem, an obvious oversight, but then, in the previous Vista installation defaults were fine. Thank you very much for taking the time to respond! -Cheers!
Configuration Desktops Headphones Speakers Audio Windows 7
