Right speaker doesn't work
Hello,
I have acer aspire 5742G,The right audio speaker doesn't work, I have check all the setting and it's okay.
Is there any one have a solution?
3 answers Last reply
More about right speaker doesn work
  1. if the settings are working fine this is likely a hardware failure
    is the laptop still no warranty? if yes, call up their techs so they can possibly replace the speaker
    if no warranty you will want to take the thing apart and check the wires going to the right speaker, most likely one of the wires either came loose or broke (likely if your speakers are installed in the movable lid)
  2. desalegn said:
    Hello,
    it has a mono speaker..
    got one too))
  3. it seems like the Acer Aspire 5742G laptop only has one speaker since i just notice that on my own laptop -.-' kind of lame
Acer Aspire Speakers Audio Laptops
