Built in monitor speakers wont work
  • Speakers
  • LCD Monitor
  • Monitors
  • Windows 7
Last response: in Windows 7
February 1, 2013 8:55:38 PM
I have a hp2009m lcd monitor the speakers wont work
More about : built monitor speakers wont work
a b $ Windows 7
February 1, 2013 8:59:55 PM
did they ever work before?
is there an audio cable from the monitor that has to be plugged in
cable with a little green plug on it
m
l
a b C Monitor
a b $ Windows 7
February 1, 2013 9:01:18 PM
and are the speakers enabled in the monitors control panel?
m
l
a b C Monitor
a b $ Windows 7
February 1, 2013 9:03:22 PM
Did you plug the audio cable ?
Quote:
NOTE: When using a VGA or DVI signal, you must connect your audio separately because a VGA or DVI signal
converts only video data, not audio data. A separate audio connection is not necessary when you use an HDMI
signal, because an HDMI signal can convert both video and audio data.
This is from the manual from the monitor.
m
l
