All the system is start but my display is not showing what can i do?
Hello,
all the system is start but my displays is not showing???it shows scartches
3 answers Last reply
More about system start display showing
  1. check you graphic card and the monitor cable .
  2. is there a bios post screen?? check that your on the right video port. some pc have two. onboard and gpu. one of them should have output. if there no output try another monitor on the pc and the monitor that was on that pc on another laptop or pc to see if it the monitor or the pc. if there no output it could be the video card or power supply. try another card then another power supply.
  3. One of the most common mistakes id peeps connect say the DVI cable to the monitor but the OSD menu (on screen display) is set to HDMI or something else.
Displays Windows 7
