Too much heat, Not enough power?
Okay, Here's the scenario. I've just bought all the parts for my new system, however in doing some reading, I realized that the Enlight 300w pwr supply might not cut it. Also of some concern is whether the hsf that comes the cpu will keep things cool enough. Here's my specs:
AMD 1.4Ghz 266FSB CPU
ASUS A7M266 Mainboard
ASUS GeForc2 GTS 64MB
CD-ROM Drive
DVD/CD-RW Drive
40GB HD
A Sound Card (undetermined)
I also have 2 case fans (one in front and one in back. I don't think I'll be attempting any overclocking in the near future, so basically I'd like to know if I'm going to need a better hsf and power supply. If so,some suggestions on what to get would be helpful too, as well as good places to get them. Thanks very much in advance!
1 answer Last reply
More about heat power
  1. You should be fine with your stuff. I've got a lot more than you, and my Hipro 300w (AMD approved), is cruising along just fine.
    <font color=green>In memory of all the Americans that died 9/11/01
    Rest in peace</font color=green>
CPUs
