[Solved] Wireless adapter problems
Last response: in Windows 7
February 2, 2013 2:49:46 PM
my internet connection (wifi) is ok but I can't get into the website I want and doing the solving problems it says I have problem with wireless adaptor? I purchased a new USB aerial and have 3/4 bars of signal usually and I had the same problem before so I don't think the signal is the problem.
a b $ Windows 7
February 2, 2013 3:52:55 PM
So you are having a problem with just one website? Does your router have some sort of firewall in it?
m
l
