G
Guest
Guest
I recently bought an AMD 1.333GHz TB. I put it in my MB and started my computer, the speed displayed was 1.00GHz.
Is this correct? I was told that I had to change the settings on my MB. Should the initial speed be 1.333 or do I really need to change the settings on my MB? I have an A7V133 Motherboard. I have changed the settings and the speed used to say 1.333, but it was unstable. I also have 512MB of sdram 133.
