Tom's Hardware > Forum > Smartphones & PDAs > Palmpilot > Treo 650 memory problems
Forum Smartphones & PDAs : Palmpilot - Treo 650 memory problems
Archived from groups: comp.sys.palmtops.pilot (More info?)
Hi
have Palm fixed the treo memory issue where it ran out of space very
quickly due to a very high minimum memory allocation for each piece of
data ? (sorry, probably not very well explained). I will buy one if it
is fixed....
Shawn H
Sponsored Links
In article <d1f277$ase$1@news.swman.net.uk>, Shawn Halpin
<halpinsf@cf.ac.uk> wrote:
> Hi
> is fixed....
> Shawn H
What do you mean by "very quickly"?
Reply to Anonymous
On Fri, 18 Mar 2005 17:13:11 +0000, Shawn Halpin <halpinsf@cf.ac.uk> wrote:
>Hi
>quickly
Quickness is in the eye of the beholder.
When they changed from volatile to non-volatile main memory, they had to
change to a new filesystem. That new filesystem has more interstitial
space, and therefore files when moved from a Treo 600 or earlier PalmOne
machine onto a Treo 650 (or T5, for that matter), require more room.
Since P1 will give you, free, a 128MB SD card,, and you can launch apps
from the card with any number of launchers, I do not have concerns about
this issue, and would much rather know that if my battery runs down, I
won't lose data. YMMV, of course.
The TSA is a test. It is only a test......
"Find out just what people will submit to, and you have found out the exact amount of injustice and wrong which will be imposed upon them; and these will continue until they are resisted with either words or blows, or with both. The limits of tyrants are prescribed by the endurance of those whom they oppress." -- Frederick Douglass, August 4, 1857.
John Bartley, K7AAY, PDX OR USA, Opinions mine.
Reply to Anonymous
Short answer: Not yet. Some type of fix is expected via a firmware
update.. but that hasn't happened yet.
You can install most applications so that they run off a SD card.
Aloke
to reply by e-mail remove 123 and change invalid to com
"Shawn Halpin" <halpinsf@cf.ac.uk> wrote in message
news:d1f277$ase$1@news.swman.net.uk...
> Hi
> data ? (sorry, probably not very well explained). I will buy one if it is
> fixed....
> Shawn H
Reply to Anonymous
johnbartley@email.com writes:
>>quickly
They _may_ require more room. P1 probably need to figure out how to
pack multiple records into the same memory block without
invalidating the existing code base. This could be by using a
storage abstraction layer between physical memory and logical
storage.
They won't accept the ID I provided... so the offer may be limited to
particular markets. It's not (yet) an issue for me anyway; I've only
had the 650 for a few days and no prior P1 data to transfer.
/"\ Bernd Felsche - Innovative Reckoning, Perth, Western Australia
\ / ASCII ribbon campaign | I'm a .signature virus!
X against HTML mail | Copy me into your ~/.signature
/ \ and postings | to help me spread!
Reply to Anonymous
"Bernd Felsche" <bernie@innovative.iinet.net.au> wrote in message
news:23jsg2x0eq.ln2@innovative.iinet.net.au...
Call them at the number listed. Their web site doesn't accept many ID's but
their human operators do.
Aloke
Reply to Anonymous
palmOne has provided an update to resolve the NVFS memory problem in
Treo 650 but its only for the Sprint network. Please check it out at:
http://www.palmone.com/us/support/d...treo650updater/
> Hi
> is fixed....
> Shawn H
Reply to Anonymous
There are 860 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
