Hi, i have got a problem with installing windows seven on my system. whenever i start the installation, it all startrs well but all of a sudden, it shows an error code. What can i do to solve this problem and what is the cause
(1) Are you using an optical or USB flash drive as the installation (delivery) device, and (2) if you are using a USB flash (or external optical) drive, is it plugged into the USB 3.0 port?
In the case of using a USB flash or external optical drive, you will have problems installing Windows 7 if plugged into the USB 3.0 because Windows 7 does not come with USB 3.0 drivers.
