G
Guest
Guest
Hello, just found this site and board and I hope those here can help me. I have tried to do some research to present this the best I can. I have a PentII 350 with 100mhzFSB Slot 1. I want to upgrade my processor the cheapest/easiest way I can. From what I gather in my searches it seems like a PentIII Slot1 with 100FSB is what I
need? I am thinking a 500-800 cpu upgrade depending on cost, thought I might be able to get one off EB*Y?
Questions--Can I just remove the old processor and put in the new one?Does the voltage requirement have to be the same? ( Some of the newer chips are 1.60/5 volts) What is SECC2? Some chips I have seen have SECC2 listed Is this compatible? Any advice/tips on actual installation? Any help would be greatly appreciated.
Thanks
David
Thanks
David
