Having connected 2 PC's via the Internet Connection Sharing wizard under WinME, ZoneAlarm seems to be denying access to the net when connecting via the 2nd PC?
This happens ONLY if the 1st PC (with the Cable Modem that's being shared) connects to the net first? If the 2nd PC connects first, everything is fine? IP addressing has been set to 'Automatically Assigned'
ZoneAlarm is running only on the 1st PC (Host) with the ICS option "This computer is an ICS gateway" enabled, but the problem still occurs?
Both PC's are sharing files/folders correctly via their 2 Realtek NIC's, no matter who connected to the net first! So there is something in ZoneAlarm that's set to block the 2nd PC, but I'm stumped as to what it can be and how to allow BOTH PC's to connect to the net independantly!
Any ideas/suggestions?
Thanks!
Thanks!
