Best laptop graphics card for multi monitor usage
Hello,
I want to buy a laptop which will take incoming broadband live streaming video and feed it to a big screen overhead projector and three more big screen(55",47", and 42") flat panel tvs. I should like to know what generation of processor, how much memory and what kind of graphics card is required. We don't know whether they required to be hard-wired or wireless just yet. Thank you.
2 answers Last reply
More about best laptop graphics card multi monitor usage
  1. This topic has been moved from the section Opinions and Experiences to section Laptops & Notebooks by Grumpy9117
  2. Hello barca72;
    Nothing there is going to be very demanding for the processor, graphics card or RAM.
    Essentially, the laptop only needs to output one data stream.
    Any of the i3/i5 dual core CPUs, any modest graphics card like a Geforce 310M or i3/i5 Sandy Bridge integrated HD 3000 graphics, plus 2GB or more RAM will get the job done.
    Upstream from the laptop:
    (1) You'll need a video splitter something like this IOGEAR 4-Port HD Audio/Video Splitter
    The bigger challenge is going to be getting cables to hook up the splitter output to the four external devices without exceeding the max distance for the type of cables in use. Which might drive the need for a more advanced splitter box and amplifiers for long cable runs. You'll have to look at that cost vs a wireless setup, depending on how you have the displays situated.
    (2) If your projector/TVs are 'network ready' you can go with a router/wireless router which will probably be more flexible than the simple video splitter.
Laptops Graphics Cards
