As everyone may or may not know I I just bought a new system.. Parts listed below..
Athlon XP 1600+
MSI K7T266 Pro2 (266a) w/ Enermax 330W PSU
512 megs of Kingston 2100DDR Ram
Asus V8200 64MB GeForce3
Diamond MX300 Sound Card
Intel 10/100 NIC
Here is my problem... When I hooked everything up it booted fine however it booted at 1050 mhz (100 FSB x 10.5 multipler) I loaded WinXP and once completed I went into the BOIS and changed the FSB to 133mhz (133mhz x 10.5 multipler) and when I did I lost video... I reset the CMOS and tried multiple methods with no luck.. the computer will not boot @ 133 FSB..
Try setting the FSB to 100MHZ by a jumper on the mainboard and disable any FSB autodetection feature on the mainboard. If you can get your video working again, power down the system and try setting the FSB to 133MHZ by a jumper on the mainboard.
<font color=blue>Another waste of bandwidth on the web. </font color=blue><P ID="edit"><FONT SIZE=-1><EM>Edited by Negaverse23 on 11/02/01 06:09 PM.</EM></FONT></P>
Also, just in case you have...do <i>not</i> set your memory to HSCK +33. It shouldn't hurt anything, but I imagine the system will not be stable at all.
Kelledin
<A HREF="http://www.linuxfromscratch.org/" target="_new">LFS</A>: "You don't eat or sleep or mow the lawn; you just hack your distro all day long."
When I set it to 133 FSB the computer powers up but I have no video... I have to reset the CMOS to get video back then set it to 100 mhz FSB... Its a factory Heatsink and fan in a Antec 1030 case with 4 fans... should be OK with cooling.
do not set your memory to HSCK +33. It shouldn't hurt anything, but I imagine the system will not be stable at all.
If you set HSCK (Host Clock)+33 and FSB at 133MHz, wouldn't the memory run at <b>166MHz</b>? Most memory modules can't run at that speed stably.
<b>Edit:</b>
I mean for PC-2100.
Good or Bad have no meaning at all, depends on what your point of view is.<P ID="edit"><FONT SIZE=-1><EM>Edited by khha4113 on 11/03/01 02:33 PM.</EM></FONT></P>
I am not running the Ram at HCSK + 33 its running at auto or I have it manually configured at CAS 2.5. I have tried to up the Vcore voltage with no luck as well... Any more ideas?
Also when I change it to 133 FSB it doesn't appear to boot just powers the devices..
I just went to the MSI site and found out that multiple people are having the same problem with Athlon XP's check it out and let me know what you think..
Still haven't found anyone who can determine what is wrong... I have called MSI but never get a callback and called AMD which blames the board... Anyone have any ideas?
