Tom's Hardware > Forum > Systems > Dell > Inspiron 4100 Battery Light Flash Sequence
Forum Systems : Dell - Inspiron 4100 Battery Light Flash Sequence
Archived from groups: alt.sys.pc-clone.dell (More info?)
If this is in the documentation I haven't found it..............
The battery light on my Inspiron 4100 (I'm talkin' the charge light on the
system itself - not the LEDs on the actual battery) is flashing with the
following sequence:
Orange (short)
Orange (short)
Orange (short)
Green (Long)
Although the system will run on the battery, it doesn't have much life in
it - it's a few years old. XP reports the battery as "97% and charging".
What does this mean?
Is that sequence code for "YOUR BATTERY IS HOSED!"? :-)
Thanks.
Jim
Sponsored Links
remove the battery and press the test light button. you will probably find
that only the first, third, and fifth led lights up, indicating that the
battery is defective. batteries do not last forever and having had a few
years use out of it sounds like it had a good run. also, regarding the
error code indicated by the battery light on the laptop itself (not the
battery itself) this is what the dell documentation says:
"If the battery status light flashes orange or is a steady orange, the
battery charge is low or depleted. Connect the computer to an electrical
outlet.If the battery status light flashes green and orange, the battery is
too hot to charge. Turn off the computer, disconnect the computer from the
electrical outlet, and then let the battery and computer cool to room
temperature.If the battery status light rapidly flashes orange, the battery
may be defective. See "Contacting Dell" in the Dell Solutions Guide."
"Jim Haselmaier" <jim@acceleratedinsight.com> wrote in message
news:415afa4f$0$211$75868355@news.frii.net...
> following sequence:
> Orange (short)
> Orange (short)
> Orange (short)
> Green (Long)
> Thanks.
> Jim
Reply to Anonymous
Correctamundo! Battery LEDs 1/3/5 light up.
Thanks.
Jim
Reply to Anonymous
There are 1305 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
