Tom's Hardware > Forum > Systems > Dell > 8400 Noise Level vs Speed
Archived from groups: alt.sys.pc-clone.dell (More info?)
Several recent threads discussed the noise level of the 8400. Most
posters reported the machine to be relatively quiet, but in general,
few hardware details were provided. The 8400 is available with the
following processor speeds: 3.0, 3.2, 3.4, and 3.6 GHz. At what point
in this progression would the noise level increase significantly? I'm
concerned that at some point the heat generated by the faster
processors will be enough to bump up the fan speed a notch or two.
I'd like to get a fast machine, but not if the tradeoff is additional
noise.
Thanks,
--buzz
Sponsored Links
Sound level is very dependant on the location of the computer. For
instance if you have it on an open shelf
that has little support that board will act as a sounding board and make
ANY computer louder. The same thing occurs with most wooden computer
desks also. Many have the computer in an enclosed wooden box with little
ventilation BUT lots of sound reflecting material around it.
If you want to quiet a machine down a LOT there are a couple easy
tricks. One is to buy some of the little carpeted self stick pads they
sell for furniture and stick 4 of them on bottom of the case as
replacements for the factory rubber feet. Another is to buy some cheap
carpeting and line the interior of the desks CPU well with it to stop a
lot of the reflected sound. To also help the machine I usually either
remove the back of the CPU well to improve cooling OR I connect a piece
of drier duct to it and route that low to the floor to pick up cooler
air (in summer I have been known to put it in front of the AC duct).
Steve
"Buzz" <buzz@off.com> wrote in message
news:efctl0tomj6mu32io2s02cd31j1kjh85qn@4ax.com...
> noise.
> Thanks,
> --buzz
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Reply to Anonymous
> noise.
> Thanks,
> --buzz
Besides processor speed, another factor to consider is the video card. If
you are not into gaming, the Radeon X300SE is an option to consider as it
does not need a fan.
Reply to Anonymous
"Don Enderton" <Enderton@nosuchaddress.duh> wrote in message
news:vsl8d.664816$Gx4.270553@bgtnsc04-news.ops.worldnet.att.net...
> Nick, is that floor carpeted?
> - Don
yep
Reply to Anonymous
I have a 3.4 GHz 8400 with 2 hard drives and a X800 video card. Even after
playing 3D games for a while, the machine is relatively quiet. If you put
your hand by the rear fans, you will definitely feel a steady flow of warm
air. Quite handy in winter, but I'll have to see how much it warms up the
room during the summer!
Jean-Luc
In article <efctl0tomj6mu32io2s02cd31j1kjh85qn@4ax.com>, Buzz <buzz@off.com>
>noise.
>Thanks,
>--buzz
Reply to Anonymous
"Jean-Luc Brouillet" <jeanluc@expertise.com> wrote in message
news:iW2vd.9321$0r.1733@newsread1.news.pas.earthlink.net...
> Jean-Luc
Generally, I don't know that the noise element can be pegged to any given
speed of processor.
I will, however, say this: *all* of the Prescott (1mb) chips run
considerably warmer under the passive heatsink than their Northwood
predecessors.
I mean *noticeably* warmer - and would certainly aid in a minor way to
heating the ambient air in a small room.
Stew
Reply to Anonymous
Dell changed my heatsink and case fan and now my computer is totally
quiet. Before, my computer was like a vaccum.
Reply to LUCIFER
"lucifer" <uttechnodragon@yahoo-dot-com.no-spam.invalid> wrote in message
news:41bd3f48$1_2@alt.athenanews.com...
Me too.
I have 3GHZ, 1GB and X300SE. Leaf blower noise was with the PC on first start-up
and never went away (only got worse with the change in pitch from the CPU fan). I
sort of accepted it for a few weeks but it did start to affect my mood :D
All the noises my PC made before are still there. The only difference now is it's
90% quieter at least.
Engineer's report said "Replaced CPU fan".
Reply to john
> Me too.
I too have the 8400 vacuum cleaner model and would like to know if there
is a "magic phrase" that you guys used with tech support to get your PC
muzzled.
I will admit that I did make one call but gave up in frustration after
not being able to communicate with the person I was speaking with
(extremely limited knowledge + language barrier = total frustration).
Should I expect to get the run around or is there a specific detail I
need to mention to point them to the appropriate flip card with the
correct response and determine my PC is noisy to the point of being
absurd and needs to be fixed?
Reply to john
"John" <john@invalid.org> wrote in message
news:II-dnUnN1sGHtiPcRVn-iA@adelphia.com...
>> Me too.
>> start-up and never went away (only got worse with the change in pitch from the
>> CPU fan). I sort of accepted it for a few weeks but it did start to affect my
>> mood :D
>> it's 90% quieter at least.
> I too have the 8400 vacuum cleaner model and would like to know if there is a
> "magic phrase" that you guys used with tech support to get your PC muzzled.
> I will admit that I did make one call but gave up in frustration after not being
> able to communicate with the person I was speaking with (extremely limited
> Should I expect to get the run around or is there a specific detail I need to
> mention to point them to the appropriate flip card with the correct response and
> determine my PC is noisy to the point of being absurd and needs to be fixed?
I would NEVER (except for the most simple thing) phone anybody for advice on
anything to do with electronics. Speaking to someone I find hard to understand
(Asian English) is a definite no-no. Very stressful.
I emailed and got a reply within a few hours and then 2 further emails asking me
to check this and that and then I got an email asking when I would like it picked
up.
They uplifted it on a Wednesday and delivered the following Wednesday. No problem.
Reply to john
i didn't bother to call or email. i went online and chat with them.
it's much better that way.
Reply to LUCIFER
news:41be91c3$1_1@alt.athenanews.com...
Good idea, but I like to keep a record of what's said.
Reply to john
>>>Me too.
>>>mood :D
> up.
Thanks for the advice. Like you, I too tried to learn to live with the
noise, but starting to get feelings similar to Jack Nicholson in The
Shining....it ain't gonna make it through the winter!
Reply to john
Hi
I have purchased 8400 with 3.4 GHz CPU, 300 GPU (no fan) and I think
the machine is noisy. I complained and had Dell drop off a case
(CPU) fan replacement but, I still hear it and the aggrevating part,
is the variable pitch. I read on Forums to turn off Hyperthreading
and to use Quiet mode on the HD (thru BIOS) and it did make a small
difference. I have searched to see if I can replace the fan with
something more civilized but ran into the problem the Dell's fan come
with a 4-wire fan (instead of 3 wires) and a 5-pin molex connector
(instead of 3-pin or 4-pin). Has any one replaced the Dell fan with
a quieter fan? and how about the wiring?
Neil
Reply to Anonymous
njarif wrote:
> Hi
> Neil
Well, I just got an 8400 and mine doesn't hardly make any noise at all.
I bought a 3.4 and the GeForce 6800 and the machine isn't any noisier
than a laptop. I have HT turned on and haven't enabled the quiet mode
on the hard drive.
Reply to Anonymous
Patrick L. Parks wrote:
> njarif wrote:
>> Hi
>> Neil
> on the hard drive.
I also have an 8400 but with a 3.2 and also the GeForce 6800. I'd like
it to be quieter without jeoperdizing the cooling function. It's not
very loud but much noisier than my Dell 8200 which sits next to it.
Reply to Anonymous
There are 540 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
