Funny pc problem
Anyone know why I have to go into gamerprofile files and change directx from earlier to later versions just to play games smoothly?
This stupid procedure must have a permanent fix.Any ideas?
8 answers Last reply
More about funny problem
  1. what the heck are you talking about. You should be able to just change it in the game.
  2. You need to buy games not pirate them...then you won't have this issue.
  3. Ok I'll simplify it for you. Farcry 3 runs slow. Even when i change the directx in game it does not change the frames per second.So i have to go to gamer profile.xml change the d3d11 from 0 start the game then change that digit to 1. This allows for smooth gameplay ok. Now that you understand what i'm talking about do you know how to fix it, permanently.
  4. I don't know of a fix but a workaround would be to make a bat file and have it replace that XML file with the edited one then start the game.
    Also you might be able to change the file and set it to read only so that the game can't over write it.
  5. thats not a bad idea actually, ill try. thanks
  6. so you are running it in directx 9. why change it?
    That's not simplifying, that's elaborating on your first post. If you'd have said it straight away none of this would need to happen.
    And no, I don't.
    And no, I don't.
    What's happened exactly? Btw I'm not surprised you don't know why.:)
Games Directx Windows 7
