My system is as follows
AMD XP 1800+
Gigabyte GA-7VTXH
Enermax 431W PSU
ThermalRight SK6 with a 60mm Delta Fan
I used Arctic Silver II as thermal compound and set the system up, so far as I am aware entirely correctly. I had the motherboard set to 133FSB and 11.5 multiplier. A soon as I turned my system on - and I mean almost *instantly*, there was a "pop" sound and an acrid burning smell, I shut down the power almost immediately, and when I took the heat sink off, I found a very small amount of a sort of browny redy sticky liquid. I'm assuming that the CPU is dead, so haven't tried it again.
Having looked at things, the only thing that I think might have been wrong is that my arctic silver II looked *slightly* too thick, but would this really cause the CPU to blow so quickly while the HSF was properley and securly clamped onto the chip?
If anyone has any ideas as to why this would happen I would greatly appreciate their input. This is my second motherboard and second CPU in my ongoing saga of attempting to set up this computer, and I'm *so* hacked off about it at the moment it's not true! <g>
Please ask if you want any further information about my setup.
Hope someone can help,
Thorin
AMD XP 1800+
Gigabyte GA-7VTXH
Enermax 431W PSU
Thorin
