Toshiba a200 power problem no dislpay
G
Guest
Guest
hi dear
hope u fine i have problem in my laptop when i plugin the adptar the system will be helt and when i
use the battery its working good
plz help me
tel me where is the problem
thanx
well the problem is obviously your "adptar"
it might have gone faulty, verify that it's still output proper voltages as written on the specifications on the label on it. If it's not working right you will have to get a replacement.
if it's working ok, then it might be your motherboard jack that has been damaged in some way and is now malfunctioning. In this case you will have to have a specialist look at the problem in order to do repairs. It could be possible to replace the dc connection on the motherboard or you might need to replace the whole motherboard, at which point I'd advise to simply buy a new laptop.
