Ok the problem is I m getting a Windows Protect Error. But if I leave the computer on untell the temp gets 45c and reboot it runs great. I can reboot and it runs.
And three days ago my cdrw drive will not load up unless in dos. It locks up windows before it even load up windows.
Here my system
amd athlon 1800
pc 2100 3 512 1.53 gigs of ram of Mushkin (I tired with one 512 megs still the same problem With the temp and Cdrw.)
1 cdrom and 1 cdrw.
two hard drives.
Is there a way I can reinstall windows 98 with out loseing some of my software. Or I can go out and get windows XP Pro and still keep the software. Like my games.
Thanks for the Info
Atol
Here my system
amd athlon 1800
1 cdrom and 1 cdrw.
two hard drives.
Thanks for the Info
Atol
