Yes No
Ads
Tom's Hardware > Forum > Laptops & Notebooks > General Discussion > Inspiron 1545 backlight problems
Forum Laptops & Notebooks : General Discussion Inspiron 1545 backlight problems
The backlight is extremely dim, almost non-visible screen contents. First time problem.
Reply to rkesslermd
This topic has been moved from the section Windows Vista to section Laptops & Notebooks by Grumpy9117
Reply to Anonymous
So when the backlight goes off, can you still see the screen contents very faintly? This is indicative of an inverter problem. Replacing it is fairly easy and cheap.
------------------------------ Desktop | i7 920 @ 3.8 | P6T | 24GB DDR3-1600 | 2x5870 CF | 3TB total | Corsair 850TX | HAF932 | XigDK | 2x24" 1920x1200 | Win 7 x64
Sager NP5793 | T8100 2.1GHz | 4GB DDR2-667 | 8800mGTX 512MB | 320GB 5400rpm | 1920x1200 17" | Win 7 x64
Reply to frozenlead
thanks for your help! Could you recommend any reliable sources for purchase and instructions for replacement or is it better done by a tech person?
Reply to rkesslermd
It's not difficult to do. There are two cables on the board, one at either end - pull them both out, replace with new board, plug in cables. You do have to take your LCD assembly apart, but there's a guide at the top of this forum on doing so.
You can get parts from this site:
http://www.laptopaid.com/
They're generally pretty nice and get correct parts.
Reply to frozenlead
There are 2042 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Cant log into windows 7
By anort3, 2 days ago:
Sorry, we can't help you get around a password as we have no way of knowing if you are...
Best offers
Top experts
