G
Guest
Guest
I custom built a PC with an Athlon XP 1700, 512 MB DDR RAM, a K7VTA motherboard, Geforce 2 graphics card, Western Digital 40 GB 7200 rpm, Windows 98 SE.
Something is wrong with it and I need advice on what I can do.
It goes really SLOW. When a program is loading, the mouse gets all jittery and slows down a lot. It takes minutes for Win 98 to boot up, and whenever something starts running, the whole PC slows down.
I downloaded a program that monitors CPU and RAM usage. It shows that when the computer is slowing down so much, the processor is being used to its highest possible level. Once it reaches 100 % is when everything slows down. Because of these tests I think it's the CPU's fault, not the RAM's, that the PC is so slow.
I need to fix this, but I'm not sure how. It's an Athlon XP 1700, running at 1.1 GHz. I don't think it's overheating because a) The case is still open, and b) It's got a big fan that is seemingly working fine (a Thermaltake Volcano S).
My dad thinks it may be the jumper settings, one of which was the CPU frequency which was put at 133 while the default was 100. That was the only jumper setting changed, so that's his top suspicion.
This is our first PC that we're building ourselves, and so far we're disappointed and hoping that we can fix this.
If you have any tips or ideas as to what is causing this problem or what could be done to fix it then by all means PLEASE reply or e-mail me.
If you need to know more about the situation before you can tell what's wrong than just ask, I'll try to answer as soon as possible.
Thanks.
-Sean
Thanks.
-Sean
