Ok, Im building a computer for the first time and have been having lots of trouble.
Heres what Im working with so far:
Epox 8k7a+ Main board
AMD XP 1500 (1.33 Ghz)
128 MB PC2100 DDR Memory
Antec 350 watt power supply
Im only giving those components because the problem is somewhere in there.
Whats Happening:
I try to turn the computer on and sometimes I get no power at all. Other times all of the fans and lights come on, but the monitor is not getting any signal.
At the moment, I cant even get the fans and things to come on.
I dont think it is the power supply because this is the second one Ive tried and am having the same problem (unless I havent adjusted something on the power supply right).
Things I have questions about that might be part of the problem
* Do I need to make an adjustment to the VCore Jumper? Right now its just on default. I havent been able to find any good info on how to adjust it.
* The cables that connect the front panel of the computer (the on/off switch, harddrive lights, etc.) are differnt from my Compaq computer. On the Compaq it is just one bunch of cables that you connect to the motherboard. With the new case, the cables are all seperate. I think I have them all hooked up right, but the LED lights arent coming on in front. Also I dont have a cable labled Power on, but there is one that is labled "DC Sw". I assume that is the power switch. There is also place for "IR Connector" but I cant for the life of me figure out what they are for. The instruction manual with the motherboard isnt very helpful.
Please give any help you can. Im not a hardware genius, but have done alot of computer upgrading and have been researching for some time. Am very frustrated and discouraged right now too.
Thanks for any help you can provide.
UPDATE:
Ok, I have an update.
After monkeying around with the computer all night, Ive found that if I unplug the power supply connector to the motherboard and plug it back in, I get a brief flash of light from the LEDs and fans and then it no power at all. If I unplug the power supply connector to the motherboard and plug it right back in, does the same thing. If I dont unplug it and put it back in, it just stays dead.
Now, when I remove the CPU, and do the same as above, fan and lights will stay running and the POST LED has code FF which my manual tells me means "Boot Attempt" (but of course it wont boot because theres no CPU in). But if I put the CPU back in, I go back to the same thing as was happening above.
Does this mean the CPU is fried? Or is there some safeguard that is shutting the power off so it doesnt fry something?
Any help would be greatly appreciated.<P ID="edit"><FONT SIZE=-1><EM>Edited by Enix on 01/11/02 11:10 AM.</EM></FONT></P>
Whats Happening:
UPDATE:
