G
Guest
Guest
I'm hoping someone will have a strong opinion or knowledge for this one.
Well, I was running a 1.1 GHZ Tbird on my Asus A7V. No problems really, except that the cpu was running fairly hot at 132.5F. I decided to go and get a Copper shim that I have heard takes about 2 degrees off the chip. I installed the shim on the cpu closed up the case and Viola! CPU burnt. I guess the shim pushed my cpu fan too high and the core did not touch the heatsink. So my real question here is, I am looking to buy a new cpu, My board only supports *supposively according to asus* 550 - 1Ghz ~." Although I have been running 1.1 ghz for over a year. I wanted to know if i would be able to run a 1.4 Ghz 200 FSB on this board. I also just purchased the thermal take dragon orb 3 7000 rpm fan for some extra cooling power. Does anyone know if this cpu will work sufficently with my board????
Thanks~
-Brian
Thanks~
-Brian
