Hi there,
I am currently running Windows 7 on a 32bit computer.
I understand the differences between the two (32 & 64). However...
I would like to install Adobe AE (Which requires a 64-bit system)...
I checked my PC and it says 64-bit capable | Yes
So, here's my question... Can I go ahead and install this program, and have it all working fine... or will it NOT work at all?
Thank you in advance
