Solved
Help with cooling pad
I would like to get a cooling pad for my HP G60 laptop that get very hot, but the only cooling pads that I could find would suck the air away from the bottom of the laptop, what I want is a pad that would blow the air onto the bottom in hoping to push air through some of the vents on the bottom, in further trying to cool it. If anyone has any ideas please post. Thanks in advance.
4 answers Last reply Best Answer
More about help cooling
  1. Hello bartsarzy;
    Blowing air INTO the exhaust vents would be exactly the wrong thing to do and probably push the operating temps up higher.
    How old is your laptop? Have you cleaned the fan and vents recently?
  2. WR2 said:
    Hello bartsarzy;
    The laptop is a little over a year old. And I cleaned the vents about a week age. The thing gets so hot I cant even put it on my lap anymore. If blowing air on the underside will not help, then want is a really good cooling pad. I dont care how much it is as long as it is a great one. Thanks
  3. Best answer
    ZALMAN Ultra Quiet Notebook Cooler Model ZM-NC1000 is probably one of the best.
    It's gotten great customer reviews on the NewEgg site.
  4. Best answer selected by bartsarzy.
Laptops Cooling Hewlett Packard
