Tom's Hardware > Forum > CPU & Components > CPUs > Overclocking with a gig of ram doesn't work right.
Forum CPU & Components : CPUs - Overclocking with a gig of ram doesn't work right.
Well for a long while I had my P4 2.0A running at 2200ghz, then I bought new samsung memory single sided one gig worth. This is rdram by the way.
Then I started getting bsod's at boot up, when I turned the cpu down to 2.0 I got no more BSOD's it rather sucks though. Oh well. Wondering if anyone else got this problem. Raystonn said that samsung can go up to 1066 with no problem and I only had it at 840 to clock my cpu to 2200ghz.
I use the TH7II which keeps the PCI/AGP in spec in fix mode, someone proved this already. Oh well.
Also the TH7II was having trouble rebooting something when overclocking, it would just not boot and had to hit reset sometimes then it would boot.
I am not sure if the fault is the cpu, memory or just the bios.
Sponsored Links
ahhh the problems of overclocking :-)
remember than when your overclocking your system bus your pushing lots of different things.
in your case the problem is most likely to be the rdram clock generator on the motherboard. your ram can handle the high speeds, but the clock generator cannot.
The lack of thermal protection on Athlon's is cunning way to stop morons from using AMD. :)
Reply to lhgpoobaa
Yeah, rayy swears up and down samsung will all do 1066....apparently not.
"The Cash Left In My Pocket,The BEST Benchmark"
No Overclock+stock hsf=GOOD!
Reply to Matisaro
I was running my ram at 880mhz I could under clock the ram with X4 but then I would be running my memory too slow.
Reply to Galvin
10% oc on a RDRAM isnt to much, is it?
<font color=red>Nothing is fool-proof. Fools are Ingenious!</font color=red>
Reply to girish
Hey this is a side-note question..but with that much RAM what if you set aside say 300Mb for a Ramdrive and then install a game on it. Would your performance increase much? I guess it would depend on the game...I bet something like Microsoft Flight simulater would benefit.
Reply to Flyboy
check HardOCP forums, strictly Intel, a few guys have done it, the limitation is the clock generator for the RDRAM.
Independant thought is good.
It won't hurt for long.
Reply to 74merc
74, I didnt mean no samsung 800 would do 1066, I was commenting on how raystonn swears ALL pc800 will do 1066(or nearly all) and how in this case, that is not in evidence.
Reply to Matisaro
all I'm saying is 90% of the time, the limitation isn't the RIMM, its the motherboard.
Reply to 74merc
There are 504 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
