Laptop Display problem
rtantri
6
Hello,
How to isolate the sections for display problems in laptops? There are LCD panel, Inverters, external VGA ports, and a section between VGA port and LCD Panel ( I don't know the technical term for it). Any suggestion on procedures to follow while fault finding will be greatly appreciated.
Thank You
rtantri
6
Thank you WR2 for your reply
I was asking a general question not any perticular Laptop. I come across a quiet a lot of them with similar symptoms, where there is display from VGA out port, and dark screen but faint display in the background, indicating a inverter problem. But many at times even after replacing the inverter module the problem persists. This is where I need some tips on solving the problem. If you can help me I will be greatful
Thanks again for your prompt reply. Sorry I could not reply earlier.
rtantri
